configure auto-provision cloud-connector server
configure auto-provision cloud-connector server [vr ( vr_name | none) | ipaddress (ip_address | none)]
Description
Configures the either the virtual router or the IP address for the Cloud Connector to use.
Syntax Description
vr Specifies the virtual router for Cloud Connector to use..
vr_name Specifies the virtual router name.
ipaddress Specifies the on-premises network management server IP address, which overrides the DNS resolved IP address.
ip_address Specifies the on-premises network management server IP address.
none Specifies the use of the auto-discovered information from auto-provision discovery.
Default
N/A.
Usage Guidelines
This command allows you to troubleshoot the Instant Port profile installed.
The following example configures VR-Mgmt as the virtual router for Cloud Connector.
configure auto-provision cloud-connector server vr VR-Mgmt
The following example configures the on-premises network management server IP address as 10.139.12.70 for Cloud Connector.
configure auto-provision cloud-connector server ipaddress 10.139.12.70
This command was first available in version 32.7.1.
Platform Availability
